Prime suspects are the ICs, and the bypass caps. Each IC has a small cap from each rail to ground, plus the overall rails each have a bypass cap to ground.
Look at each IC closely, are any cracked or discolored? Look on the underside of the board under each IC, any signs of browning? Find the little bypass caps, and black spots on any?
Securely clip your ground probe to ground near the connector. Now probe the -15v line at various places, note the reading carefully. The traces will have a small but readable resistance, so if you see something like 115 ohms here, and 116 ohms there, then here is closer than there to the actual problem. Remember, one of the ICs is on the jack board, so unplug that board from the preamp board and see if it affects your 115 ohms.
If you are reduced to opening jumpers, start near the middle of th board, so if possible you can divide the board into two halves. Then take the half with the problem and try to divide that in half., etc.
