Samson Mixer
  • Samson Mixer
    I have a XM 610 Samson powered mixer here , the owner said it was blowing fuses . I couldnt find any blown--might have been replaced. Powered up with a limiter and it seems fine.
    Power up with no limiter and it wont blow a fuse -BUT , R299 started smoking after several minutes and looks cooked. right next to it is Q218 . That is also getting pretty hot.
    One problem is R299 on Amp2 pcb , is not on the scem , comparing it to Amp1 pcb, which looks somewhat identical , it looks to be a 3.3k / 3w .
    Some of this , like Q218 , will be hard to test due to the mounting of everything .
    I replaced R299 and have -68v one end and -68v the other
    on the Amp1 pcb , R163 i have 63v on one end and 68v on the other end
    at Q118 I have 69v / 69v/ 68v
    One thing, the amp was on for about 5 minutes and R299 and Q218 did not get hot
    could it have been R299 or maybe something drawing to much current through it ?
    Samson XM610 PS.pdfSamson XM610 mixer.pdfSamson XM610 PA.pdf
    I can't get your schematic links to open. That doesn't mean it couldn't be on my end. Anybody else?
      ..nor me.
        There is another thread around here for this model, with schematics. I think it is erroneously named MX610
          Schematic: Samson XM610.zip
            i just found a burnt tiny transisitor--kinda hidden. its Q221
            another resisitor thats on the Amp2 pcb is R300 but its not on the schematic --it appears to have brown/brown/black stripes , but tests 3.3k
              perhaps that was orange orange red until it got hot and oxidized the color bands?
              What does R300 connect to? Since channel 2 goes up to R294, they could have added some parts as a revision. I see not circuits in the 300 range on any page.
                yea , it looks like it may have seen some heat , i cant tell where 1 end goes , pcb is still in the case , but other end goes to Q222
                  Ive got parts on the way--guess i can start there
