This Crown DC300A amp goes into thermal shutdown a lot earlier on the Left side. Everything seems to be ok with that channel, no DC on the output and it's biased a touch colder than the Right side. What could make that side run hotter than the other side?
Crown DC300A One Side Overheating
Biased a bit colder, but runs hotter? Does seem odd. Are you fan cooling the heatsink fins? It doesn't take a whole lot of power to trip thermal switches on the DC300A (I've done it with only 40W per channel), and even modest fanning can allow you to run them to hi power without thermal shutoff.This isn't the future I signed up for.
Does one side run hotter even if the amp is run unloaded (no speaker load)?
And, FYI, every one of those I've ever worked on has been full of cold solder joints. It would be a good idea to give it a once over and make sure solder connections are all up to snuff."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
ANything is possible, but it is probably not the outputs, it is more likely they are being turned on too hard.
How did you decide they were biased cooler?
here is a simple dirty trick. Turn both biases cold. Monitor mains draw. Now slowly advance one channel bias until the mains current JUST starts to rise as you turn it up. Stop and back off a hair. Now do the same to the other channel. Now both channels shpuld be set just below the point exstra mains current starts to flow.
Noww does it still over heat?Education is what you're left with after you have forgotten what you have learned.
