These are good results. The PWM chip should be operating so it narrows the problem to after that point.
I suggest check you have continuity from the junction of C4/C5 (sorry I meant C4/C6) to pin 2 of TR2 i.e. the transformers are not open. Also check that you have around 160V at the same point pin 2 of TR2. All that being OK it's time to pull the FETS T3 and T4 and test them. Care need to be exercised when handling FETs as they are very sensitive to static. Also, make sure the main filter caps C4 & C6 are discharged before touching.
This is a difficult PSU to work on since it requires power from the second supply to operate.
