Originally posted by jomama
View Post
First Act amp repair
This topic is closed.
Originally posted by The DudeYou could always add some wire to the pot legs and solder into the board. Use the mounting nut to hold it into the chassis.
1. The board might flop around a bit because the wires won't be as tight.
2. I don't know how thick the wire should be and doesn't wire length change things?
Originally posted by rjbSo, what did you get as a replacement?
Originally posted by jomama View PostI PM-ed you my address to send the 50K pot. I can return the smaller one(s) in swap if you include a return address. You'll let me know what you consider fair and we'll work it out.
-rbDON'T FEED THE TROLLS!
Originally posted by J M Fahey View PostWe *definitely* need pictures here, since we are on post#24 and still do not know what kind of pot you are talking about.
* 3 leg? ... check .
* "single output" ? ... what does that mean???
* you talked about ON-OFF and clicking. Standard 3 leg pots do not "click" nor turn anything ON-OFF
* "the right lead spacing" .... which would be? ....
* "the pots I ordered" .... I have no clue about what you ordered.
We need pictures showing old and new pots and pcb where it sits.
Also measure lead spacing on old and new.
And pot case diameter(s).When the going gets weird... The weird turn pro!
Originally posted by jomama View PostDo you mean soldering wires to the pot legs and then making the connection to the board? I see two issues with that:
2. I don't know how thick the wire should be and doesn't wire length change things?......"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
The photo above is the pot that broke. You can see it's a 10mm spacing and it's out of the shell. Sorry it took so long. I used AWG 24 wire to connect the pot as suggested. The wire length is about 3". I tried shorter but it was harder to work with. It works now. The volume board that single pot normally sits on is separate from the main board and small/narrow. That was the reason I was concerned with flexing.Last edited by jomama; 11-18-2018, 12:26 AM.
I stated the lead wires were 3" long. I needed to use wire extensions because the pots bought had ~7mm spacing. The wires are not touching but they are bent to fit. I don't understand why photos are critical here to determine the potential for amp oscillation. DrGonz78, are you going to save the day here with the right pot?
Originally posted by jomama View PostI stated the lead wires were 3" long. I needed to use wire extensions because the pots bought had ~7mm spacing.
Typical modern pot spacing is between 7 and 8 mm ; you showed old one with apparently 10 mm spacing.
Simplest Math and Geometry tells us you need 2 or 3 (two or three) mm extensions.
Then you mention they are 3" long, which means 76 (seventy six) mm long ... WTF?
We are very interested on how did you manage to fit a tiger inside a cat sized box.
Since your description is not clear, we ask for pictures.
Extra long wires placed randomly can and do introduce cross coupling between amp parts which must be separated and definitely can be a cause for oscillation.
Originally posted by jomama View PostYou can see it's a 10mm spacing and it's out of the shell. Sorry it took so long. I used AWG 24 wire to connect the pot as suggested. The wire length is about 3". I tried shorter but it was harder to work with. It works now. The volume board that single pot normally sits on is separate from the main board and small/narrow. That was the reason I was concerned with flexing.
https://www.taydaelectronics.com/pot...ntiometer.html
https://www.taydaelectronics.com/datasheets/A-1931.pdf
On the fuse blowing: My uneducated guess is that the problem is more likely a physical short: flopping PCB; exposed wires touching something they shouldn't; random solder blob... something like that.
-rb
EDIT: I posted this before seeing #42.DON'T FEED THE TROLLS!
