I picked up a pair of 18" subs a few weeks ago to give my system some more low end but am running into a bit of a dilemma powering them. They are 8 ohm's, so if they are ran in stereo out of the power amp which is rated at 4 ohms then they would only be getting half power and need almost double the power to get the wattage to them that way. With the amp bridged i would need a total 8 ohm load to get the full power from the amplifier. There again is the issue, the speakers chained together are either gonna be a 4 or 16 ohm load. So basically still the same scenario only able to draw around half power. My other option is 2 smaller amps bridged, one for each sub which would end up at 8 ohms bridged and allow each sub to get full power without having to run a big double the power amp just to get these things sufficiently powered. Now my question is, are there any power amps out there that aren't really high end that run at 8 ohms in stereo, and 16 bridged, or that will run 4 ohms bridged. I have been looking and haven't really found much in that department. Any positive input is appreciated.
powering pa subwoofers
This topic is closed.
You didn't specify the most important specs. What is the power rating on the subs? What are power ratings on the amp? Or, maybe at least provide model numbers for the gear. Without knowing what we're dealing with, I'll make a generic statement. It isn't about power. It's about SPL. It's fairly likely that the difference between running them bridged (if you could) vs. running them stereo wouldn't be noticeable. Don't sweat power ratings. The important question is, can you get enough sound out of the subs without clipping anything?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Also, what's the application? Is this for Sound Reinforcement, like a working band's PA system, where the venue constantly changes, or is this for your home system, where the room size is constant, and you can optimize speaker placement to reinforce LF rather than have the room modes cancelling LF? Assuming your wife/girl friend are agreeable with such things. Spkr sensitivity / efficiency likewise comes into play. As The Dude says....it's all about SPL level and NOT so much about amp power.Logic is an organized way of going wrong with confidence
To elaborate: Double the power does not equate to double the perceived volume. You'd need 10X the power for that. Doubling the power is something like only a 3dB change. Hardly worth worrying about in most cases."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostTo elaborate: Double the power does not equate to double the perceived volume. You'd need 10X the power for that. Doubling the power is something like only a 3dB change. Hardly worth worrying about in most cases.
Originally posted by The Dude View PostYou didn't specify the most important specs. What is the power rating on the subs? What are power ratings on the amp? Or, maybe at least provide model numbers for the gear. Without knowing what we're dealing with, I'll make a generic statement. It isn't about power. It's about SPL. It's fairly likely that the difference between running them bridged (if you could) vs. running them stereo wouldn't be noticeable. Don't sweat power ratings. The important question is, can you get enough sound out of the subs without clipping anything?
Originally posted by nevetslab View PostAlso, what's the application? Is this for Sound Reinforcement, like a working band's PA system, where the venue constantly changes, or is this for your home system, where the room size is constant, and you can optimize speaker placement to reinforce LF rather than have the room modes cancelling LF? Assuming your wife/girl friend are agreeable with such things. Spkr sensitivity / efficiency likewise comes into play. As The Dude says....it's all about SPL level and NOT so much about amp power.
It'd be better to have the cabinet and amp models. Is that a max SPL spec, sensitivity spec, something else? Sans that, use your ears. Do they keep up at the volume level you'll be running at? There are lots of variables- crossover point, cabinet design (front load/horn load), manufacturer, etc. I'd trust my ears over any specs, which can be grossly inflated by some companies."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
that is not the max spl, that is the sensitivity spec 1 watt at 1 meter. I do not have an amp for the subs yet or a crossover so i have to way of doing the ear test, that is why i started the thread in the first place was to get an idea if there were any amps that would provide max power at 16 ohms bridged vs 8, and to kind of get an idea maybe of the minimum wattage i could get away with at a 8 ohm load on an amp that is rated at 4.
Originally posted by Leo_GnardoI think that's a pretty fair assumption. I'd use whatever amp you have on hand, forget about bridge mode, paralleling, series wiring the speakers, no fancy stuff. Run 'em straight up & see if you have adequate thump for your needs. AND you would be better off having more speakers than doubling up on power or trying any fancy modes. What? more subs? Hmm.... if that's what you need. Better to share power over a number of speakers, than stressing the speakers with excess power which, as you know, leads inevitably to silence. Right in the middle of the gig, ugh. We can do without that, right? Plus, more cones moving = more volume overall. Speakers have "power compression" which is just as it sounds: when you whack em with lots of watts, they do not respond in a linear way as you approach their claimed power limit.
Most amps have an 8 ohm/per channel power rating spec. Since your subs are 8 ohm and you have the specs for them, just look at the 8 ohm amp spec and get an appropriately sized amp. I'm not sure why you're concerned with the 4 ohm spec as it relates to this application?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostMost amps have an 8 ohm/per channel power rating spec. Since your subs are 8 ohm and you have the specs for them, just look at the 8 ohm amp spec and get an appropriately sized amp. I'm not sure why you're concerned with the 4 ohm spec as it relates to this application?
Originally posted by The Dude View PostAny amp is more power at 4 ohms than it is at 8. It's ohms law.
