realizing this may not be the right forum, but hoping an electronics whiz can help a brother out...
I have a Polk DSW1000 subwoofer w/ a built-in amp. The amp powers on OK, but will not start producing sound until after it has warmed up for anywhere between 10 and 30 minutes. After that time, it is not unusual for it to kick in for a second, then kick out, then kick in for 2 seconds, kick off, etc until it finally outputs sound continually, and then it will work OK until I power it off & let it cool down. Re-powering starts the process over again.
To my fairly novice mind, this seems like it might be a capacitor, so I pulled it apart today to look for any obviously bad (i.e. leaking) capacitors. I did not find any, but I did find two that have their tops swollen, and I wonder if they might be it..
Does anyone know the best way to troubleshoot those? I can de-solder them & put in new ones if I need to, but hoping there was maybe some way to test them while they are still in the unit?
Or, does it sound like I am off on my diagnosis, and maybe it's something else? Any suggestions on where to start looking? I can use a meter, but am not super versed on electronics. If I could find a shop to send it to, I would, but I can't find any shops that will work on it for some reason.
Thank you so much for any replies! I am attaching some pics of the two suspect caps...
