Mostly newb here. Looking to fix this amp. Don't know what more to add besides the title. The fan isn't hooked up but doesn't seem to effect playing bass at low levels. Any help is appreciated.
Please help! Behringer KX1200 master volume stops past 4 and no lines work just fx return
Please be more specific about the master volume. If you use the regular input, everything works fine til you get to 4 on the master?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Line 3 is the input for bass guitar but none of the lines work besides fx return. I plug the bass into fx return and I can play up to the master volume level 4. After I turn the master volume knob past 4 I get a mild static sounds from the amp but no sound from the bass. Turn it back below 4 and sound comes back. Don't know if the fan not being connected is an issue but doesn't effect play below 4. Please Lemmy know if I should clarify anything further.Last edited by Padredelaverde; 02-23-2023, 03:54 AM.
It's possible the master pot is bad as well as the other problem.
Was the amp working good for you previously or is it something that you received in this condition?
Do you have basic electronics tools and experience?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I received in this condition. Yes I have basic electronic tools and experience. I have a bit of trouble reading schematics and applying that to electronics, but if monkey see, monkey can do. If someone says, turn your voltmeter to this, put here and here on master pot, and that will tell you if it's bad or not. Like the fan reconnect looks like (I could be wrong) 2px1 but I don't know which terminal is the positive and which is negative, but if some shows me where to solder I can do it.
To help clarify the JPB comment, by having it work when connecting to the FX return, that means the power amp section of the Behringer is working correctly. The preamp section of the Behringer is where the problem lies. He does not mean a separate preamp unit.
Originally posted by Jazz P Bass View PostThe FX return should go directly to the power amplifier.
So you have a dead preamp.
I would suggest that you check the preamp supply voltages.
Originally posted by Delta362 View PostTo help clarify the JPB comment, by having it work when connecting to the FX return, that means the power amp section of the Behringer is working correctly. The preamp section of the Behringer is where the problem lies. He does not mean a separate preamp unit.
- Likes 1
IC1 and IC2 are 7815 and 7915 voltage regulators. Verify that you have +16V at pin3 of IC1 and -16V at pin3 of IC2.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Did you mean -16V at IC2? It should be negative not positive. If so, I think those voltages are close enough. Now you need to find out if those voltages are getting to the IC's.
Check that IC6 and IC10 have +15V at pin4 and -16V at pin11.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
IC7 looked a little odd like there might have been a loose attachment. I touched it and this happened. So I think I found where at least one source of where the issue is. Does this mean I need to repair the pcb, seeing as how it's now missing the 2,3,4,and 5 input spots, in order to properly reattach IC7? The whole area looks questionable at best.
I really appreciate all the help. I hate revealing my massive wealth of ignorance on topics usually but I suppose it's the only way I'll learn. Can someone tell me where to solder the fan to? It looks like x12p but I could be wrong. I also don't know which side is positive and negative. I'm trying to upload an attachment but it appears I'll have to size it down since it will exceed my upload quota.
