I am working on an Ampeg BA115 bass combo amp. I notice that as the note fades out, the sound becomes distorted. What would cause that?
Distortion as note fades out.
- Likes 1
The rails test only 36v instead of the 40v on the schematic.The low voltage 16v tests fine.
The main filter caps tested low. They are supposed to be 4700uf. One tested 4300uf, and the other tested 4100uf. I changed them out, and the voltage did not change. It is still 36v.
Always make contemporaneous mains voltage measurements, and the secondary V AC.My band:- http://www.youtube.com/user/RedwingBand
- Likes 2
Originally posted by pdf64 View PostThose symptoms line up with some types of speaker faults.
Originally posted by Axtman View PostThe rails test only 36v instead of the 40v on the schematic.
Are you on a bulb limiter?
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
g1,
TomCarlos posted the correct schematic diagrams in his post.
I was using a light bulb limiter until I was sure that nothing was going to blow up. Then I switched over to plugging directly into outlet strip.
BTW, with the light bulb limiter the voltage was plus/minus 34 volts.
Is the +/- 36V right at start up or after the bias creeps up from 5mV. How high does it climb to?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
For ease of viewing, I created JPEG versions of page 1 and 2.
Update - and just a side note .... Periodically, I like to have large paper versions of a file. So I take the JPEG to Office Depot and use the self serve machine to create 11x17 copies. If you have a JPEG, it will auto size to fill out the sheet. If you have PDF files, they print as a smaller size. So this is another reason to convert to JPEG. If you do not have Adobe Standard, you can try using the Microsoft Snippet tool or similar.
Last edited by TomCarlos; 08-12-2024, 04:45 PM.It's not just an amp, it's an adventure!
