Hi,
I wish someone would help a bit with this problem, it slowly drives me crazy…
It is Polytone 100, combo, NO IC in power amp, it is discrete version.
Power amp was completely dissasembled, cleaned, every component tested.
All components seems good outside PCB, PCB was cleaned, both output transistor sockets are new.
Power transformer is rewired to 220V, bridge rectifier is new, both big elkos are reformed, minimum leakage at full voltage.
Components/transistors are those written on schematics:
https://el34world.com/charts/Schemat..._schematic.pdf
Bias diodes D1,D2 are both MZ2360, protection diodes D3 is MZ2361 and D4 is MZ2360, all tested good.
There is one detail, different than attached schematics: R12 was missing, anode of D1 is tied to junction of: base of Q4+cathode of D3+100hm collector resistor of Q3.
All the rest is wired eaxtcly as per schematics, it seems all original populated.
Preamp is all OK, works well, all voltages are correct, sounds good, scope test OK.
Power AMP is problematic:
WITH LOAD connected: Negative rail voltage fall to -8,7V, Q5+Q7 conduct when load is connected, positive rail stay at +28,2V
Without load all is well.
For testing purposes I changed output transistors from original 2N5881/2N5879 (tested good) into MJ11015G/MJ11016G (both new)
Measurements results – WITHOUT load, input shorted:
-both rails used with safety resistors 22ohm
-neg.: -28,9V, pos.:+29V
-voltage accross each safety resistor is 0.3V (c.13.5mA for each rail)
-driver Q4 (b-e voltage = 0.59V)
-driver Q5 (b-e voltage = 0.59V)
-power Q7 (b-e voltage = 0.018V)
-power Q6 (b-e voltage = 0.018V)
-bias Q3 (b-e voltage = 0.7V)
-DC in output c.-12mv
-test with scope and tone generator shows both drivers works well, without load
Measurements results WITH load, input shorted, powered for a few seconds only:
-voltage accross safety resistors= neg.rail 18V, pos.rail 0V
-neg.: -8,7V, pos.:+28,2V
-driver Q4 (b-e voltage = 0.46V)
-driver Q5 (b-e voltage = 0.72V)
-power Q7 (b-e voltage = 1.34V)
-power Q6 (b-e voltage = 0V)
-bias Q3 (b-e voltage = 0.36V)
-DC in output = -6V
Please, guys with experience with Polytones...
-DC in output = -6V
