I can't figure out why I am getting +31 DC volts on the speaker output of the Peavey 260D power module of the Peavey Standard Mark III. I have checked all the usual suspects (electrolytic capacitors, ouput transistors, and driver transistors) and they test okay. Nothing is burned or look damaged. All the solder joints are okay. What am I missing here?
Here is the schematic. 260D schematic.pdf (THIS SCHEMATIC IS INCORRECT. U1 OP AMP IS WRONG. DO NOT USE!)
