What is the purpose of this FET?
  • What is the purpose of this FET?
    What is the purpose of the FET (Q5) in the following circuit? Pin 3 is the input to the amplifier (U2)..
    Click image for larger version  Name:	image.png Views:	1 Size:	61.6 KB ID:	983919
    Here is the full schematic:
    crate_tx_15_sch.pdf
      Looks like a mute Fet. C19 takes a bit of time to charge at turn on. Q5 shorts the signal to ground until C19 is charged.
        ^^^^^^^ Yes, that!
          Thanks guys!
          The TDA-7240A is such a small wattage amplifier I would not think it would mind being slammed with a signal right away.
          Maybe this has something to do with removing popping sound. Buth then the speaker is small and I would think a small pop wouldn't hurt them.
            It's slow to unmute and quick to mute (when the power is removed.)
