I recently bought a 1980 Music Man 212-65 amp.
All the parts in the circuit appeared to be original. I replaced all the e-caps and just about all the diodes. I replaced the two bipolar BJTs in the phase inverter. The new BJTs contributed a massive improvement in the amp's tone! I picked up 5 new LM307H op-amps (round form-factor).
Through trial and error I have confirmed there are some contact issues within the op-amp sockets. Oxidation likely I assume. I tried spray-cleaning the contacts in the op-amp sockets. The sockets are very small. The spray I used doesn't seem to be having an effect. Is there a contact spray you recommend? Deoxit maybe? Alternatively, anyone know where I could source replacement op-amp sockets? Searching the internet I have not had any luck with the round sockets needed.
I have set the power tube bias to 25 mV as per the Music Man instructions. The amp is really sounding great.
