Originally posted by unparalleled
View Post
temporary intense glow/dull flash on filament when heaters are turned on
I don't buy the "burning air" thing either.
(To be pedantic, your V8 burns air already, or rather burns the oxygen in it by combining it with gasoline. If you don't believe me, try bunging up the carburettor so no air can get in. This really improves the gas mileage because the engine won't work and you can't drive anywhere.)
If a tube flashes, it's because there is a relatively long piece of heater wire left uncovered by the white stuff that forms the heater-cathode insulation.
The resistance of tungsten increases with temperature, so if one part warms up quicker than the rest, it will drop more voltage and heat even more, in a vicious circle until it's dropping nearly the full 6.3V and glowing white hot. This is what the uncovered lengths of heater do, because the lack of white stuff reduces their thermal mass. As the rest of the heater begins to warm, the white hot ends dim down and eventually go out.
Some people say that this is deliberate, as it slows the warm-up of the rest of the heater, protecting the white stuff from cracking due to thermal shock. I suspect that Philips just found it difficult to coat the heater all the way to the ends.Last edited by Steve Conner; 03-25-2009, 12:44 PM."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by Steve Conner View PostI don't buy the "burning air" thing either.
Some people say that this is deliberate, as it slows the warm-up of the rest of the heater, protecting the white stuff from cracking due to thermal shock. I suspect that Philips just found it difficult to coat the heater all the way to the ends."Reality is an illusion albeit a very persistant one " Albert Einstein
Just don't crack the glass. if the burning air inside the tube manages to get out, it could catch the earth's atmosphere on fire, and then we'd be screwed.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostJust don't crack the glass. if the burning air inside the tube manages to get out, it could catch the earth's atmosphere on fire, and then we'd be screwed.
I read somewhere that 12AX7As and 7025s don't do this, it's just 12AX7 (early US) and ECC83 (euro) valves, something to do with 12AX7A being designed for series string operation. It's most definitely the low initial resistance of the heater. For what it's worth, most of my mullard 12dw7/7247s do this too. Sure makes startup look dramatic!
Sure is dramatic - its a little fireworks party when you flick the switch on.
Hey unparalleled, where d'ya get them gonzo meters?Building a better world (one tube amp at a time)
Originally posted by tubeswell View PostSure is dramatic - its a little fireworks party when you flick the switch on.
Goniometer, google it ( direction finding device. )
(Not for detecting severity of VD)
Filament flash or Bright glow
Most Euro made ECC83 tubes do this on power up.
No harm is being done, the filaments just flash or glow bright for a few seconds.
My friend has a few ECC83 tubes in his Hi Fi amp.
They have been inservice and doing this for years in his amps.
I believe they do the same thing in regulated D.C. filament supplies.
NO worries
