I like the sound of the JJ's long plates too, but not as much as the Sovtek LPS...
What I'm about to say amounts to nothing more than my opinion, but take from it what you wish.
Lately I'm using Sovtek LPS tubes for everything except for V1 in high gainers. My usual 12AX7 tube is the RCA gray plate. The RCA sounds as good as the Sovtek but is usually non microphonic. Where the Sovtek is almost always a little too microphonic for V1. So I use the Sovtek WA short plate tube for V1. Not as dynamic as I'd prefere. The WA sounds good but lacks some top end clarity, but when I'm cranking an amp it all evens out and the WA is dead quiet. So my tube line up for the amps I use and sell is usually a Sovtek WA followed by all Sovtek LPS. Unless NOS tubes are requested and then I like the RCA's and Mullards.
The only way to know if you like a tube is to try it. I've tried a lot of tubes and IMHE there is no point at all in buying preselected/rebranded tubes from Ruby, Groove or Mesa. I've always done just as well or better buying the original MFG labled product.
JM2C
Chuck
JM2C
Chuck
