one of my 6L6 is microphoning when tapping cabinet right above the tubes or when I tap it lightly when amp is on, reverbs on 9..it also has a different sounds when tapping all four tubes with a screwdriver...you can easily tell which tube it is..
I take that to be a sign that the one tube is going bad??? sounds like the tube is broadcasting a reverb sound like a mic is on it..
also developing a kinda strong hummmmm especially annoying when playing at high volume 6 and up...can I also attribute that to the 6L6 tubes going bad especially that one tube that's microphoning???
I'd like to stay close to the original sounds of my twin reverb so are JJ 6L6 tubes a good choice??? the store has only a set of JJ 6L6's for $85.
and when biasing them I put the meter on the no#3 pin right???
aloha, popoahi
aloha, popoahi
