^^^^^^ What he said. What is the voltage at TP4 or the cathode of V1B?
Fender pro junior bad transformer and red plating v3 tube
I feel that all is in order with my components and tried different tubes. I still have no signal passing through this nightmare of mine. I feel the problem is in the pre amp section but am not skilled or smart enough to figure it out. I took reading off all tube pins with the hope that it might mean something to someone who can help me.. V1 PIN (1) 3VDC (2) 0 VOLTS (3) 3VDC (4) 3VAC (5) 3VAC (6) 209VDC (7) 0 VOLTS (8) 2VDC (9) 0 VOLTS ------------ V2 (1) 151VDC (2) 23VDC (3) 3VDC (4) 3VAC (5) 3VAC (6) 209VDC (7) 0 VOLTS (8) 2VDC (9) 3VAC ----------- V3 (1) O VOLTS (2) -13VDC (3) 0 VOLTS (4) 3VAC (5) 3VAC (6) 0 VOLTS (7) 324VDC (8) 0 VOLTS (9) 299VDC ------- V4 MEASURED IDENTICALLY TO V3 ANY HELP WILL BE APPRECIATED AS I AM LOST THANKS, TOM
Your very first reading. Pin 1 of a 12AX7 is a plate. You have 3v, but it should be more like the other pins 1 and 6, 150vDC. My first suspect is R10 is open, a 100k. It would be very difficult for a tube there to short that pin to ground anyway, and since you already tried other tubes, that reinforces my theory. Oh, wait, I have a second idea. The socket for V1 is on the little socket board, and the connections to it come through that ribbon cable next to the socket, from the main board. If that ribbon has a broken connection, then you lose voltage. R10 is near the center of that row of seven resistors near the ribbon, find it on the parts layout diagram. See if there is 3v on the bottom end or more like 230v. If 3v like on pin 1, then the resistor likely open, or possible unsoldered, but if more like 230v, then the ribbon connection is probably bad.Education is what you're left with after you have forgotten what you have learned.
