This is a new thread about an old topic. The JJ6V6 tubes seem to surprise (mostly good) in terms of performance. An earlier/related thread is at OK New issue with JJ tubes!. My question is about reliability and peak currents I'm measuring from this tube.
The pp stage has the following params - which are not extreme compared to what others have described with JJ6V6s.
CT B+ = 450V
Screens = 350V
OT Primary = 6.6k
With an 8 ohm resistor load on the 4 ohm OT tap I get 23w (~clean) and I measure ~225ma peaks from each tube when Va drops to ~50V.
I've seen other 6V6 amps with only about 100-120ma peak currents, so I'm a bit surprised and uncomfortable since 225ma is literally off all the tube charts I've seen and well beyond any Max Ia spec I've seen.
Does anyone have experience with Ia current peaks like this and 6V6 reliability?
This amp has played for about 10-15 hrs so far without noticeable problems - but current performance is no guarantee ....
CT B+ = 450V
Screens = 350V
OT Primary = 6.6k
