RCA 6V6 loose and making noise
  • RCA 6V6 loose and making noise
    A customer just bought a RCA full tube set out of a 64 Deluxe Reverb. While biasing them, I noticed one of the 6V6s wouldn't settle down. Also, if I wiggled it the current would jump up and it made noise through the speaker. I see one pin tip is not sealed with solder like the others. Is it OK to try to flow some solder in there in hopes there is a bad connection? There is some movement between the glass and the base on both tubes.
    Yes, deafinitely. Doesn't always work, but it's worth a try re soldering base pins. On loose bases, a number of adhesives have been recommended. I use a little epoxy, dabbed into the gap between glass & plastic base with the tip of a toothpick. No need to completely fill the gap. 3 or 4 spots, spaced more or less evenly around the base/glass gap, works fine. I'm sure other suggestions will follow.
      It worked, problem solved. It almost looked like it had never been soldered, surprized it ever worked reliably. I finished with a little bead of Gorilla Glue clear, I am pleased with the results. A pair of matched 1964 RCAs saved. My customer, who just went on a $700 tube spree while on tour will be pleased as well.
        Good on ya Randall! You wonder how many tubes that could have been saved, wind up in the rubbish bin.
        Gorilla products are getting popular, some here have mentioned them, but I have yet to go shopping in the gorilla zone. Maybe it's about time I did.
          Gorilla duct tape (or Duck tape if you're old school) is about the most durable of it's type on the market. I haven't come across something it can't "repair"
          But I have to wonder about about using one of their glue products for a tube base. My concern would heat and it's eventual affect on the flexibility of the adhesive. Unless a product is specifically designed for such things you pretty much count on failure sooner or later.
            I run into that often keeping the rental inventory running. As you said, doesn't always work, but sure is nice to restore the 6th KT-88 in a sextet that wasn't lighting up due to bad solder joint inside one of the heater pins. I hadn't thought about the toothpick shims to tighten up the base to the bottle fit. I like that!!
              As it turns out, the tube is still defective. Soldering cured the nasty noise when slightly wiggling the tube, but it still won't settle down on idle. It will jump 4 -5 mA if I tap it lightly, and sometimes throw my meter off scale with a pop if I clank the base with a tweaker. Seems like it has an internal short that my tester isn't picking up. It's gotta go, I don't trust it. Sad. I would have tried to get a refund, but this customer is flush from a 3 month world tour and can't be bothered!
