Originally posted by Gonzo72
Blackstar Stage HT60
Okay, what have you done in the way of troubleshooting so far?
https://music-electronics-forum.com/...8&d=1519629152
Edit: That was weird. A minute after I posted this the whole thread was edited.When the going gets weird... The weird turn pro!
I may be mistaken but I think there may have been multiple threads started for the same topic, and maybe a moderator combined them but accidentally put the first response ahead of the question?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Gonzo72 View PostWhat section was it moved to?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Did you try the recommendation giving by Alexradium??
"disconnect all the main PT secondaries and start powering through a bulb limiter in series"
Edit: Not that we should suspect the power transformer first but it might be easy enough to rule it out. Also running the amp through bulb limiter or monitoring current with a variac will be crucial to not blow fuses while testing. If not the transformer then try turning on with the power tubes removed, light bulb limiter connected too. At that point if it pulling too much current focus on bridge rectifier and even a faulty mains filter cap.Last edited by DrGonz78; 09-08-2019, 08:13 PM.When the going gets weird... The weird turn pro!
