New Month We are at $45 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
These are great amps! I am a BIG Univox tube amp fan.
The ONLY mod I would make to this amp (aside from recapping it, which is not a mod, it's maintenance) is right at the input. There is a .01uF series cap and 4.7M resistor to ground on the first stage, providing a "contact bias" scheme. This scheme is fine until you hit it hard with either powerful humbuckers or booster of some sort. The first stage then becomes prone to "blocking distortion", which is a condition where the capacitor cannot discharge fast enough and the grid of the tube builds up an increasing DC sharge as a result. Eventually, the tube gets driven into cutoff, and the signal gets "blacked", hence the name. It's a real nasty, raspy sound that results.
It would be best to remove the cap, add a jumper in it's place, then open up the cathode connection to ground and add a 1.5K resistor paralleled with a 22uF cap between the cathode and ground. This more ubiquitous setup makes the amp more user friendly, and just sounds better.
