I hesitate to ask this question after being in this field for a long time. None the less here it is:
What is the relationship between gain & gm? I'm assuming Gain = Emission although I understand the meter reading isn't reflective of the actual gain of the tube since it's a Good-?-Bad general meter indication.
I know gain is Vpp out over pp in. Simple.
I also know that gm is the relationship between Vin in vs Plate current out.
Seems that tubes that have higher gm are the tubes with less gain eg 12AU7 or 12AT7 vs 12AX7. Gm for a 12AT7 is 4000 which has a lower gain than the 12AX7 with a gm of 1250.
Tube testers eg my Hickcock 666A of course read both. If you have the 'English' set for reading the gm of the tube, it is just a matter of resetting the 'English' knob to the emission setting to then see the emission reading...SO, they have to be related as it is just a matter of resetting the 'English' parameter to go from a gm reading to the Emissions reading. I guess I'm assuming the Emission reading is a reflection of the gain of the tube.
Anyway I may be way off base in my thinking here....any ideas?
Thanx, glen
Thanx, glen
