Wondering, if I put 6SJ7 in a place calling for 6SL7 (mainly, old ampeg amps), would that work with no harm to the amp? I have about 20+ 6SJ7 tubes laying around...
6SJ7 in place of a 6SL7?
It doesn't work because the 6sj7 is a pentode and the 6sl7 is a dual triode. They are completely different tubes.
But if you have an amp that uses a 6sj7 tube you could test the ones you have for microphony and sell them. I've never dealt with them but from what I've read non microphonic 6sj7's are hard to come by."Take two placebos, works twice as well." Enzo
- Likes 2
Having recently reworked an old Magnatone that had the 6SJ7 to a dual 6SL7, it was fun and not incredibly difficult given that my amp was hand wired and not PCB mounted. Not sure what the situation of your amp is, but if it's PCB socket, then it wouldn't work without major surgery. If it's wired, you could rewire it (and add a couple R and C) to make the dual triode work.
Originally posted by Delta362 View PostHaving recently reworked an old Magnatone that had the 6SJ7 to a dual 6SL7, it was fun and not incredibly difficult given that my amp was hand wired and not PCB mounted. Not sure what the situation of your amp is, but if it's PCB socket, then it wouldn't work without major surgery. If it's wired, you could rewire it (and add a couple R and C) to make the dual triode work."Take two placebos, works twice as well." Enzo
- Likes 1
Damn, I misread. Sorry about that. And you're right, taking two triodes down to a single pentode doesn't seem like it would work unless the two triodes were just basic gain stages in series. Then you might be able to replace the two with one, albeit with a much lower gain factor.
