Boss CE-1 chorus/vibrato LED not working
  • Boss CE-1 chorus/vibrato LED not working
    The LED not working is the Normal/Effect, the other works fine. The LED lights up when on the diode checker of my meter. The switch is good, tried another in its place. I re-soldered the area of ‘22’. Q8 and Q9 aren’t shorted and resistors off them are good boss_ce1-chorus.pdf Does anyone what this problem could be? I wonder what the little arrow at ‘21’ is suppose to connect to.
    Are you working on D101?
    That is driven by Q14.
    21 looks like 'circuit ground'.
    https://archive.org/details/manualli...p?view=theater
      "21" looks like -14V supply to me.
        edit: I thought this was a regular boss stomp pedal that ran off battery, but I see it is not.
        Your schematic is for an ET-10 unit, is that the same as the CE-1 ?
          I see elsewhere that 'ET-10' is printed on the CE-1 circuit board.
          In case there is any difference, here is what seems to be a slightly later (D) version of the schematic:
            Back to the facts.
            What voltage do you measure at point 21?
            This voltage supplies both D101 and D102.
            Do I understand correctly that it is D102 and not D101 which doesn't work?
            Does the unit work otherwise?
              -12vdc at 21. It’s D102 that’s not working
                That might be just a bit too low (i.e. not negative enough).
                Are you getting the +/- 13V supply voltages?
                  On the anode of D102 there’s-14
                    So you have -14V at point at point 22 and -12V at point 21?
                      Yes that’s it. The effect is working, don’t know if I said that already. Anyway I have gig to head to
                        So the LED is reverse biased and can't light.
                        Actually it's not plausible that point 22 would be more negative than point 21.
                          It wouldn’t surprise me if I’m interpreting my readings in reverse. I’ll check that
                            Make sure the cathodes of D101 and D102 are connected.
                            If D102 doesn't light, try a new one (might have drifted somehow).
                              You could also try swapping D101 and D102 for a test.
                              marsbahis betturkey
