[ATTACH]3810[/ATTACH]
Here's an original schematic of a Big Muff. What I want to try is to make a Muff with 4 gain stages and 2 clipping sections with 2 gain controls (possibly ganged pots?) and be able to mod a stock Muff instead of having to build it from scratch. SO, here's what I drew up (more like cut and pasted)
[ATTACH]3811[/ATTACH]
As you can see, I bypass the tone stack and used the last gain stage (which will be slightly different than the mod schematic) as a clipping stage and use the 3rd gain stage as a buffer instead of as a clipping stage. I did something like this before with great results but not quite in the same fashion, it sounded like a high gain tube amp, very good for Heavy Metal, of course that pedal crapped out on me after fiddling with it too much (ugh)
As for the tone stack I don't think it'd be a good idea to use it late in the circuit because of the volume losses it causes, but I was thinking of using a presence control (pot and capacitor) so there's at least some control over the tone.
Any thoughts?
Any thoughts?
