can i use a 47k pot instead of a 20k one?
  • can i use a 47k pot instead of a 20k one?
    hi, i have a damaged boss pedal which needs pot replaced, which used a mini 20k b pot
    i have a 47k b pot, can i just use that instead and if so what would be the difference?
    thanks
    note: would be for a sustain knob, or a tone knob. choice of either.
    What pedal?
      a boss cs-3 compressor sustainer modded with monte allums opto plus kit
        It seems to me that one would have better success, and more predictable functioning post-change, by sticking the 47k in the tone-control position than the sustain position. It will NOT function identically to a 20k pot, but will be able to attain the same tone at each extreme of rotation, if that's what you want.
        Ideally, you want to score a pair of 36k resistors, but if you can only find 39k, those will do.
        Install the new pot like the old one, but solder a 36k resistor between the wiper and each outside lug. Like I say, it will not behave identically in the middle, but it will be identical electronically at each extreme.
