Hello,
I have an old "Aria Echo Chamber" that I recently hooked to a true bypass switch in the fx loop of an amp and it works very very well. The only problem I have is with the speed of the repetitions which are too fast, the slowest is pretty medium-fast and it goes up to very cool but not that usable in this context speeds through a six stepped knob.
I have thought to slow it down...halving all the speeds would be ok, without changing the existing parts I would like to add something to offset all the speeds. The switch knob has a series of resistors of increasing value.
What do you suggest to do?
Thanks.
Thanks.
