Hi,
quick intro: I'm Ton, from Amsterdam. I work in IT, and like to mess around with guitars and effects.
I want to build a Spyder power supply as shown here: http://www.geofex.com/Article_Folders/Spyder/Spyder.htm using a WPDLXFMR-2 transformer.
However, I want to make two changes and am not 100% sure this is OK. I may want to have more than 100ma current occasionally, so I want to use a LM7809 (1A) instead of the 78L09 (100ma). I guess that as long as I don't come near the 300ma that's supposed to be the max of each 11v ac out of the trasnformer this should not be a problem, right?
Also, I need to order some 4700uf caps for another supply. I thought I might use these instead of the 220uf caps in the schematic as well, as I'm getting them anyway and some extra buffering can never hurt. But I'm wondering if the initial charging of these caps could pose a problem as I don't know how high the current will be and if the 300ma from the transfomer can handle this. Does anyone know if this could be a problem, and if there is a way to calculate these currents?
Thx!
Thx!
