Ibanez TS5 bypass problem
  • Ibanez TS5 bypass problem
    I need to push the pedal several times to obtain switching from the flip-flop circuit. I suspect a cap needs substitution and maybe a different value.
    The problem is the same going from bypass to effect or vice-versa.
    Thanks for your help
    m.p.
    I've got one that does the same thing. Maybe a bad component, but I just figured it was the switch.
    - Yogi Berra
      those switches do eventually go bad. They are quite tiny, too! Ibanez used to have replacements, dunno if they still have them. They should also be available from the usual suspects: Mouser, Digikey, etc.
