This pedal switch is fine, i tested w/ a meter and it indeed switches momentarily as it should. When I first apply power via wall wart the power LED is not lit. Then I push the switch and voila it lights. Then I push the switch again to turn it off and it does nothing - the pedal stays on. I've tested R49 and R47, they're both getting 9v on both sides of them. R42 is getting 9v as well. Other than that I'm not experienced enough to know what to check next.
Boss DM-3 not flip-flopping
If you are getting signal but no effect, the delay chip/s is probably suspect. I don't have a schematic handy. You may want to check for correct voltages on any transistors and opamps. If you want a quick fix attempt you might just replace the delay chip, I've found that delay pedals that work but have no delay that it's usually a bad IC. If it were me I'd confirm that all the voltages are good and that all connections are good, then order the IC.
