Ibanez FL9 noisy
  • Ibanez FL9 noisy
    This FL9 flanger pedal has a motorboating sound, when you crank your amp volume and you crank the speed control, with the effect switched off.
    Similar schematic here: http://www.schematicheaven.com/effec...01_flanger.pdf
    Any ideas?
    I pulled the fet Q102 out and I still heard it. I've replaced the 1st opamp IC101 and it's still going on.
