Hi everyone!
I just finished building a Rangemaster off of RG's GEOFEX design. Works great, but I am wondering why this version was designed to use 9 volt battery supply as opposed to the 4.5v supply of the original.
I realize the 4.5v battery is very strange but there are other ways to get that "Original" Voltage.
And...isn't that the way the pedal was designed anyway?
I have tried both voltages and the unit sounds very different. So I guess my question is, "What is the optimal voltage to run the Rangemaster on?"
I suspect that tweeking and tuning based on the 9 volt as opposed to using a 4.5v with the original spec parts will get further away from the original design intent. Therefore I am not really wanting to tweak yet, just want to make it as close to the original design as possible. Then I will tweak from there. I just need that original bench-mark for tone and function.
Any thoughts?
Thanks in advance.
Any thoughts?
Thanks in advance.
