boss/roland say they don't seel these pots anymore. need a 50kL and 100kg mini pots. these are PCB mounted and are smaller than your standard 16mm mini pot. I don't know what "g" stands for w/ the 100k but a lin is probably ideal, however an audio is fine as backup. if anyone has these or know who does give a shout.
Boss DS2 pots
Tubes and More have Korg Pots which are 11mm square although you may have to chop off the mounting flanges.
The Panasonic Rotary Potentiometers/EVUE/EVUF that cjlectronics pointed to
are available in slightly different configurations and are 9mm square
may be worth checking the pdf
http://www.panasonic.com/industrial/...AOK0000CE4.pdf
although it may be hard to buy 2 !
Guess you will have to be creative with whats available.
