Hi my name is Rob and I'm new to this forum.
I was wondering what would happen if I use a power supply that is rated higher than the effect. For example, I have a 9V 1.3 amp power supply. Can I use it for an effect that calls for 9V 300 milliamp? I also have some power supplies from old laptops. One is 16V 1.88 amp. Will I fry my effects if I use it? The plug in is compatible. If using it is not advised, is there a way to reduce the power output to make it compatible? Thanks in advance.
