MXR Omni Flanger/Chorus inop
  • MXR Omni Flanger/Chorus inop
    Need some help here, I have a MXR Omni effects unit and the flanger/chorus effect is NW. I checked the bias voltage and clock signal, both are present. There is a input and output at the sad1024 chip, I'm not exactly sure how they sould look but the output is following the clock signal. The LED comes on, the direct signal is present but no effect. Any suggestions? Thanks in advance.
    Not sure this will help, but I've seen a potentiometer open up on one unit a while back that had me confused for a bit. May want to verify correct values on those pots.
      Good idea, checked all the pots in the circuit. All OK
      Would've been nice if one was open though...
      Checked all the solder joints too, just to make sure. No problems there either.
        I thought the Omni used SAD4096 chips?
          It does have a sad4096 for the delay section, the flanger/chorus has the sad1024.
            When the wet signal is omitted, any flanging or chorus effect will disappear. Consequently, it is extremely common for manufacturers to simply cancel the wet signal as their "bypass" technique. The dry signal will continue to pass in both bypass and effect mode. I don't have a schematic of an Omni (wish I did, though!), so I may be off. Possible that the switching arrangement for lifting/enabling the wet signal has gone awry? So, is there a JFET or CMOS switch that might have blown?
              There is a flip/flop in both the flanger/chorus and delay circuits, not sure what for but I'll check this out later. CD4013BE
              I wish I could find the schematic also, I checked with a few local repairmen but no luck so far.
                The 4013 is used to supply a clock signal to the delay ICs.
                You can buy the schematic here: MXR Schematics. It's $20 but if you send me a copy I'll pay half.
                  Actually, if you send me a copy as well, I'll pay a third!
                  Interested in old, rare, unusual or just plain bizarre music equipment?
                  www.nicosonic.com
                    Did you ever buy the document? I've seen one for sale that is missing the delay/flange IC chips and want to figure out if its worth buying. No such thing as a pin for pin replacement, right? Thnaks
                      Hi,
                      Unfortunately, I never got it.
                      I don't know of a replacement for the SAD4096, apart from building a small add-on board with another BBD and associated adaptive circuit. I wish I did!
                      www.nicosonic.com
                      slot siteleri
