I own a couple of old Chandler Tube Drivers from the 80's (BK Butler signed) that show up an annoying AC noise, especially when I switch on compressors. I suspect that the electrylitic caps could be an issue, since the age of the units. I was thinking of substituting also their internal transformer with a modern mini toroidal type (the trafo present at the moment is an aftermarket unit I installed when I bought the pedals, since the original ones had US 110V specs).
Could a 3,2VA toriodal transformer be appropriate? These will give approx. 0,133 Amperes output power at 12V.
