wh-1 problem, need some pro advices
  • wh-1 problem, need some pro advices
    hello
    this is my first post on the web
    hope you guys can help me with this problem
    i'd bid for a pedal on december
    after waiting for a month+
    the wh-1 arrived at my doorstep
    i opened the package and just plug it on
    and then the adapter start to burn
    so i looked at the power source
    read the spec
    input for the adapter is 120v but here in malaysia we use 240v for home outlet
    supposed to read it first before plug the pedal
    anyway
    i used my other adapter
    the one that can support malaysian home outlet
    it was harman pro 240v input and 9v/1300mA output
    the pedal function
    but i felt like the pedal is heating up
    right on the input for power supply area
    i went to check the pedal at local electrical store
    they said the voltage regulators might need a replacement
    i wonder maybe someone more professional here can help with my problem
    should i look for a new parts?
    do i need to find some vintage parts for this effect?
    will it effects the tone of the pedal?
    thank you
    does anyone here have the scematic drawing fror wh-1, really appreciate your kindness
    hello
    i just bought a wh-1 from ebay last month
    the pedal has arrived on my doorstep last friday
    it was a quiet deal though
    the seller sent me a harman pro 120v input adapter
    i didn't noticed about this, i thought it used 240v input adapter just like here
    after switch on the pedal
    i quickly pull the adapter because worrying anything happen to the pedal
    after that i went to a local guitar store at my place
    and send the pedal for a check
    the next day the technician told me that the voltage regulators on whammy's circuit board kinda short out because of the adapter that seller gave me
    so i need a schematic for reading the circuit
    can anyone here please help me
    please
    we gotta help this whammyless guy
      Hi umair.
      *Maybe* you got lucky and only the regulators shorted, without further damage.
      Replace them and check the unit.
      If you have a Variac, better, start with very low voltage and rise it slowly.
        thanks
        Originally posted by J M Fahey View Post
        Hi umair.
        can i ask you something?
        did voltage regulators meant to get heat up?
        the pedal did work but i have to replace the adapter for purpose
        i used the exact adapter that can support 240v home output current
        after a few second, the pedal is heating up right on the power input area
        because the voltage regulators are glued on the back side of the body
        some said it's usual
        but it's like you can fry an egg on it
          Hi umair.
          Regulators do heat up, because they are "lossy" and "eat" the voltage difference, but "frying eggs" (in practice: unbearable to human hand) is not normal.
          Get a multimeter, post here what the WH1 power jack says, what the user manual says (google for one if you don't have it) and what your 240V to żż?? says.
          The important thing is your expensive pedal (still)works, let's keep i that way, don't use it until the problem is solved.
          Post a couple pictures, showing the power jack and any labels close by, the power adapter, and if you opened your WH1, a couple closeups of the regulator area.
            Hi there,
            I am Edmund Jude from Selangor, West Malaysia. I am a full-time professional Audio
            Repair Engineer with more than 15 years experience in
            repair of professional audio equipment and musical instruments.
            I have Sound Engineering qualification from SAE and electronic repair
            certification as well.
            I Specialize in Servicing & Repair Of The
            Following Types Of Equipment:
            VALVE AMPLIFIER
            ACOUSTIC AMPLIFIER
            BASS AMPLIFIER
            GUITAR AMPLIFIER
            KEYBOARD AMPLIFIER
            POWER AMPLIFIER
            POWER MIXER
            HOME AMPLIFIER
            5.1 CHANNEL AMPLIFIER
            GUITAR PEDAL & GADGET
            KEYBOARD
            DIGITAL PIANO
            FOR FURTHER ENQUIRIES OR TO ARRANGE TO GET YOUR
            AUDIO EQUIPMENT OR MUSICAL INSTRUMENT REPAIRED CALL : 012-2174777 (Mr. Edmund
            Jude) or click on AUDIOSERVICES.COM.MY
