I have been working on my Sansamp Classic to get it to work. And gone as far as removing all switches, and most of the input buffer. When this was all together, I had the controls cranked and barely got any noise. If I hit the strings hard I got the noise but sounded shorted, gated sounding. When I turned the volume control I get a crackle sound (crackle not okay). Now with switches removed, and input buffer still the same problems.
I am still getting almost 1 volt lower on my first stage of IC1 (see below). Does anyone have any voltage readings for this project? Should these pins all be close to the same voltage? What components affect the voltage for that first stage?
Q1
Drain 7.93v
Gate 4.183v
Source 0v
IC1
pin 1 4.381v
Pin 2 4.58v
Pin 3 3.67v
Pin 4 0v
pin 5 4.34v
Pin 6 4.38v
Pin 7 4.41v
Pin 8 7.93v
IC2
Pin 1 4.386v
Pin 2 4.386v
Pin 3 4.357v
Pin 4 7.91v
Pin 5 4.373v
Pin 6 4.383v
Pin 7 4.382v
Pin 8 4.36v
Pin 9 4.24v
Pin 10 4.25v
Pin 11 0v
Pin 12 4.354v
Pin 13 4.383v
Pin 14 4.359v
Q1
Drain 7.93v
Gate 4.183v
Source 0v
IC1
pin 1 4.381v
Pin 2 4.58v
Pin 3 3.67v
Pin 4 0v
pin 5 4.34v
Pin 6 4.38v
Pin 7 4.41v
Pin 8 7.93v
IC2
Pin 1 4.386v
Pin 2 4.386v
Pin 3 4.357v
Pin 4 7.91v
Pin 5 4.373v
Pin 6 4.383v
Pin 7 4.382v
Pin 8 4.36v
Pin 9 4.24v
Pin 10 4.25v
Pin 11 0v
Pin 12 4.354v
Pin 13 4.383v
Pin 14 4.359v
