I have an old (not reissue ... I think) yellow OD-250. These apparently sound inferior to the original gray OD-250. The gray used an LM741 chip and mine uses a TL081CP. I'm going to get a 741 at some point, but I'm curious what you guys think, am I likely hear any substantial difference?
I think what these things do best is when they are used as a booster (with a bit of hair). They give a fairly hefty level boost. But if the goal is to simulate tube amp distortion it fails. Sounds pretty bad. BUT, the gray 250 sample that tonefrenzy.com has sounds awesome.
So, am I likely to hear a difference between the two opamps?
