GFS Onboard Guitar Enhancer wired to Foot Switch??
  • GFS Onboard Guitar Enhancer wired to Foot Switch??
    I ordered the parts 3PDT , led's etc but was curious if anyone has already REMOVED THE PUSH/PULL switch from one of these and wired it to a 3PDT Foot sytle switch...?
    Was curious if a schematic or drawing was available for routing the solder connections on the PC Board to the Foot Switch...Also need how many ohms the potentiometer is...(but it hopefully will be stamped on it)...
    thanks all
    Over on DIY Stompboxes there's a guy who stuffed one of those board into a 1290A box for the worlds tiniest delay pedal. None of what you ask will be at all tricky once you've got it in hand and can make some measurements.
    My rants, products, services and incoherent babblings on my blog.
      Thanks !
      thanks I'll go check into that...!
