EH memory man/drops volume
  • EH memory man/drops volume
    Hi there
    I have an old EH memory man and it has one problem
    It drops volume
    It works ok for 2 min and after that you hear the volume goes down
    Anybody knows what that is or what I have to do to fix it???
    Thank you all in advance
    Originally posted by Jay View Post
    Hi there
    It drops volume
    Well, the very first thing that I would do is this:
    Clean all pots (knobs and sliders)
    Clean all switches
    Make sure the quarter inch jacks are clean and making good contact.
    I realize that your symptoms seem consistant after 2 minutes, but sometimes dirty pots, switches and contacts just behave that way for a number of reasons.
    Use a good quality spray cleaner that also has a light lubricant.
    I hope that maybe you might be lucky and this might work.
    after that, the only thing I know, would be to have a professional tech look at it.
    Edit: Oh, one more thing---If you have it sitting, for example, on top of a tube amp that has a grating on the top, or somewhere else that transfers a lot of heat to it, try re-locating it to a cooler locaton---Just a thought
