MORLEY PVO
  • MORLEY PVO
    I have just acquired this pedal and of course out of curiosity I took the back off to have a look inside, now I am even more curious. The circuit board (Dated 1992) is made for mono or stereo and has the basic circuitry ldr's led's 3 resistors etc.
    The board also incorporates a stereo (or two mono) circuit which utilises 2 x MC3340P chips. I can't find this circuit among the Morley Schematics so can anyone tell me what this circuit does.
    Cheers Dave.
    The datasheet of the MC3340P suggests using it as a compressor or an expander.
    The call the ic an electronic attenuator.
      Thanks JP, As I am using it for Pedal Steel I'm wondering whether it would be worth adding the components to see what it does.
      Dave.
        First let's establish that it is a 3340 and not a 3403 with a typo. Morely was fond of that quad op-amp for a while.
        At the same time, that would be 8 op-amps over the two chips, andI can't see even a stereo volume pedal as requiring that much.
        The Motorola 3340 is an electronic attenuator chip. I've got a couple in my parts bin. What's nice about them is that turning them into an attenuator that can be controlled by a simple 50k variable resistance to ground is a breeze. That feature also means that wiring up a pan control that uses a single linear pot with the wiper at ground is also a breeze.
        They CAN be controlled in dynamic fashion as you would a VCA, but apparently their specs are not that good for such applications. I seem to recall building a 3340-based compressor from an lectronics Today project and was not all that impressed.
        Whatever you do, don't confuse them with the CEM3340, which is a kickass, and ultra-rare, VCO chip.
