I'm rebuilding an effects pedal and have found the 2SC1849 transistor to be a good update for what came originally in this effects pedal. The problem is that this 2SC1849 transistor is apparently available in two different pinouts!! The one I need is (with leads facing down, flat side facing you) pinout: E B C. I bought a dozen from a well-known pedal parts supplier and his came in pinout: E C B. As I'm replacing transistors in a previously existing circuitboard, these won't work for me. Does anyone know where I can get 2SC1849 transistors with a pinout: E B C. It's really strange (and confusing) that the same part number can have 2 different pinouts!?!
Thanks in adv.,
Bob M.
Thanks in adv.,
Bob M.
