hey guys...i've got a an idea that i'm nearly ready to apply. i want to put a piezo element on the batter head of my bass drum that will trigger gate to be "open" whenever the drum is hit. the gate is between a guitar and amplifier. the guitar sound will only pass through to the amp when the drum is hit.
i need some help working on the logisitics...
i'm starting here: Taint Paul » Triggered Drum Light
i have two thoughts... one is that i can use the circuit above to trigger an LED to interact w/ a photosensitive resistor. (the resistor being open when the LED is off. closed when the LED is on.) the photo-resistor will simply be in between an input and output jack.
the other thought is to use a momentary relay switch in place of an LED. hitting the drum vibrates the piezo which sends the voltage to the relay to allow the input and output jacks to "see" each other.
one of my concerns is the amount of decay allowed for each guitar note. i don't want it to be such a short burst to have a stuttering effect, i'd like each note to have a bit of breath and taper off rather than be cut off abruptly. (which makes me think the LED photo-resistor is the better choice.)
if the piezo circuits output voltage went into a charging capacitor before the LED, the LED could fade out gradually which in turn could fade the volume of the guitar signal out w/ it.
if anyone has some words of wisdom, please lay it on me! i'm looking to get this project up and running in the next few days. thanks!
