This is most likely a question for Mark Hammer... Mark if you're out there in cyberspace I need your expertise.
This pedal is Rev C which is actually quite close to Rev D. I believe the difference is that Rev C uses NE571 and Rev D uses NE570 companders.
This pedal has no "effect" output. I've traced the signal all the way to U8A. Actually the signal stops at the junction of R38/39. Should I get signal on my scope here? Sometimes I know that signal won't show on a scope on op-amp inputs. V- is good on U8 pin 4.
