Another broken DL4 Pedal thread.
  • Another broken DL4 Pedal thread.
    Hi, I bought a DL4 brand new from the states a few weeks ago. I currently live in England. It worked fine battery operated for a few days, but I left the batteries in overnight with the jack still connected to the input, so by the time it was morning, the batteries ran out. I then went and bought the power supply. I connected it and nothing... recharged the batteries, put them back in and nothing.. knowing that I don't have a warranty as it was purchased from another country, I opened it up. I checked the voltages and I got the following with battery:
    D12: 3.3v
    D16: nothing (only with power supply)
    U14: 2.6v (pin 1 and 5)
    U20: 1.6v (pin 8/1 and 5)
    U21: 1.6 (pin 1 and 3)
    With the power supply:
    D12: 9.2v
    D11: 9.9v
    D16: 0.4v
    U14: 7.7v (pin 1 and 5)
    U20: 1.8v (pin8/1 and 5)
    U21: 1.8v (pin 1 and 3)
    Now I know these reading are a bit messed up. I replaced the U20 and got the exact same reading, so that cant be the problem. I also replaced the D16 and it's also the same. What could be the problem?
    Thanks,
    Alexi
    Can you post or link a schematic?
      At the + of C40 you should have +3.6v DC
      If you don't the most likely culprits are <in order>
      D16 <3.6 V 1 Watt Zener>
      or D11 & D12 <both 1n4002>
      When all is well You should have 3.3v DC at + of C58
      And +6.6V DC at + of C48 .
      The unit will not work unless the board is screwed back onto the chassis because
      the chassis is used as part of the ground-path.
      Zim
