OK. Just checking. I thought you said it was working OK. And while the daisy chain cable is thinner that the cable on the main power unit, as I said, the cable on the power unit itself is in fact quite thick for such units. There may be another one with thicker copper wire, but I don't know of it if it exists.
There's another funny thing about copper wire. Flexibility (and with that, immunity to work hardening and breakage) is conferred by making the individual strands inside the cable thinner. House wiring is done with single-strand wire, and it's very stiff. It's also easy to break if it's flexed a lot, because what matters in flexing is not the overall cable size, but the radius of the bend in relation to the thickness of the individual copper strands. To a solid #12 wire, a 1" radius bend is pretty abrupt. To finely stranded wire, it's almost impossible to work harden the wire because the individual strands slip along one another and support each other so that it's hard to get a tight-radius bend on any one of them. #00 welding cable ( I weld a little, for fun) is quite heavy, but the good stuff is almost limp. It's made of many, many strands of very fine wire. It spends it's entire life being bent around. It's not the thickness that keeps it from breaking, it's the fine stranding. That's impossible to see without cutting one open. And the copper composition, especially an annealing step before encapsulating the wire in a vinyl overlay can't be told without some lab work on the individual strands.
Another thing that enters into the wire breaking stuff is abrupt transitions. Wire crimped into a metal sleeve will usually break right at the end of the sleeve, because the sleeve forces a tight bend right there. Inserting soft, gooey stuff to make it harder to bend it abruptly is another way to prevent bends with a small radius compared to the strand diameter. It's the radius of the bend compared to the strand diameter that determines bend sharpness and eventually work hardening and breakage. Another abrupt transistion that doesn't get thought about much is tinning wires. If you tin a stranded cable, the solder wicks up between the strands and turns it solid up to the point the solder stops. There is no soft transition possible. Tinned wires which are flexed often break right at the solder edge, even up in side the vinyl overcoat.
I understand that the daisy chain cable looks thin to you. And it is in fact much thinner than the main cable, the one that's permanently attached to the power unit. But from our other discussion on diystompboxes, I thought you liked the idea of using a separate cable, on connectors, which could be replaced, like the IEC power cables.
With the daisy chain cable being easily replaceable by connectors, it's entirely possible to replace it by the guitar-pedalboard equivalent of "monster cable", super-thick cable that will handle zillions of amps. It might be more expensive to do that, but the magic of the market is that, having seen this conversation, some enterprising young entrepreneur will likely introduce "Godzilla's Daisy Chain", an eight (or ten, twelve...) connector 9V power cable where the wires are half an inch thick, and made out of "oxygen-free, cryogenically relieved linear-crystal virgin copper yada yada".
As I noted, a lot of this comes down to how much can the maker afford and can you afford to buy. For instance; if I got the boss to authorize manufacture of the "Godzilla Daisy Chain", with #14 fine-stranded copper, 1/2" diameter plugs on the power connections to hold the thick wire, and possibly gold-plated connector barrels to make it look fancy to the uninitiated (but really offer no real increase in performance), how much would you pay for that daisy chain?
