Hey guys and gals, I have a silly question that I can't seem to find an answer to anywhere.. here goes.
I have 2 amp heads, 1 clean and the other dirty. I have a tonebone switchbone to switch between the 2 amps and that works great but I recently purchased a deluxe memory man with tap tempo, which is very pricey and souds great! My question is, can I hook it up to both amps effects loop? The effect chain would be (I guess) amp 1 effect send into the delay's input. The delay out into amp 2's effect return. A patch cable would then connect amp 1's effect return to amp 2's effect send. Does that make sense? Will it work in keeping the actual 2 separate guitar amp's clean/dirty tones intact? I am gonna blow something up or ruin the DMM?
Any help would be great and I know, you can call me chicken for not just trying it out... :-)
Thanks again,
Marc
Thanks again,
Marc
