Mesa Boogie V Twin pedal - volume loss fix
  • Mesa Boogie V Twin pedal - volume loss fix
    If you're suffering intermittent volume drops on one (or both) channels it could be the series vactrols on the tube outputs playing up. To test - hot air makes them go OC.
    An easy permanent fix is to replace with DIY shrink wrapped LED/LDR vactrols, but do both to ensure consistent output levels. Works perfectly.
