I have an older EHX 10-band EQ to repair. Seven of the slider shafts are essentially broken off at the surface of the chassis, such that there is still something you can move back and forth if you work your fingertip in there, but it's not as grab-able as it used to be.
Given that replacements for handicapped slider pots generally have to be exact (you can't just attach a different brand/size to the chassis like a rotary pot), I figured folks might have some idiosyncratic approach to making such pots a little more usable. So what do YOU do when the shaft snaps?
